Inleiding
This guide will show you how to replace the battery in a DOD LS300W Dash cam. For this guide, you will need a tool to open up the dash cam, a soldering iron, and the a little soldering skills. This is a relatively easy repair, but be careful with the soldering iron to not burn yourself.
Wat je nodig hebt
Using an opening tool, pry open the seam on the bottom of the dash cam to separate the two parts of the device.
Once again, thank you for checking out this guide and I hope it helped!
2 opmerkingen
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
