Ga door naar hoofdinhoud
Dashcam DOD LS300W Battery Replacement
Wat je nodig hebt
  1. Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: stap 1, afbeelding 1 van 3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: stap 1, afbeelding 2 van 3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: stap 1, afbeelding 3 van 3
    • Using an opening tool, pry open the seam on the bottom of the dash cam to separate the two parts of the device.
  2. Dashcam DOD LS300W Battery Replacement: stap 2, afbeelding 1 van 2 Dashcam DOD LS300W Battery Replacement: stap 2, afbeelding 2 van 2
    • Notice the connection of + and - on the top left side of the inside of the dash cam. Make note of this as it will be important to remember when you solder on the new battery.
    • Desolder the old battery. This is a 250mAh.
  3. Dashcam DOD LS300W Battery Replacement: stap 3, afbeelding 1 van 3 Dashcam DOD LS300W Battery Replacement: stap 3, afbeelding 2 van 3 Dashcam DOD LS300W Battery Replacement: stap 3, afbeelding 3 van 3
    • The new battery is 400mAh. and fits just in the battery location.
    • Solder in the new battery.
    • Then place the new battery into the space previously occupied by the old battery.
    • See the difference between old and new battery.
    • Be careful to solder the positive side of the new battery into the same spot that the old battery was soldered into.
  4. Dashcam DOD LS300W Battery Replacement: stap 4, afbeelding 1 van 1
    • Put the dashcam back together.
    • Charge the battery to the full level, and you are ready to go.
Conclusie
Once again, thank you for checking out this guide and I hope it helped!
Pierre
542 Reputatie
3 handleidingen geschreven
2 opmerkingen
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
Russell Edwards - Antwoord
Hi Russell, I found this battery on Ebay.
Good luck.
Cheers.
Pierre - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 6,341
