Ga door naar hoofdinhoud
Daisy Model 10 Carbine Cocking Lever Replacement
Wat je nodig hebt
    1. Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: stap 1, afbeelding 1 van 3 Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: stap 1, afbeelding 2 van 3 Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: stap 1, afbeelding 3 van 3
      • Make sure the safety is on!
      • Place the carbine with the saddle ring and leather thong facing upwards.
      • Locate the screw head on the cocking lever.
      • There should be one on either side of the saddle ring and one on the cocking lever assembly.
      • Place a #2 Phillips Screwdriver in the 11/16ths of an inch, matte black screw on the cocking lever assembly. Twist with a counter-clockwise motion.
      • Completely remove the screws.
      • Be wary of the black washers on the other side of the Carbine. Be sure to keep track of them once they fall out after the screws are removed
      Vraag FixBot
      Voeg opmerking toe
    2. Daisy Model 10 Carbine Cocking Lever Replacement, Removing the Lever: stap 2, afbeelding 1 van 2 Daisy Model 10 Carbine Cocking Lever Replacement, Removing the Lever: stap 2, afbeelding 2 van 2
      • Remove the cocking lever by placing your dominant hand’s fingers through the cocking lever handle.
      • With your fingers in the handle, slide the lever towards the butt of the carbine.
      • Finally, pull the cocking lever and carbine in opposite directions to replace the cocking lever.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Timothy Gachot
237 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 34
Altijd: 2,876
