Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the four screws with a Torx T8 screwdriver to access the back con board.
Remove three screws using a Phillips #00 screwdriver.
With tweezers, gently remove the large con board tab.
Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
Peel off the rubber grips to access the screw holes.
Remove the back board and set it aside.
Pull apart the back plastic panel.
Once the back panel is off, you will have access to the motherboard.
Disconnect ribbon tabs 1,2,5,8G, and 3.
Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
Then remove the plugs
With the Phillips #00 screwdriver, remove the two Phillips screws.
Carefully remove the plastic. This will help you gain access to the power button panel.
With a Phillips #00 screwdriver, remove the two screws on the power button panel.
Gently pull the power button out from the panel. Replace it with a new one.
