Ga door naar hoofdinhoud
DJI Phantom 4 Advanced Remote Controller Power Button Replacement
Wat je nodig hebt
  1. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: stap 2, afbeelding 1 van 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: stap 2, afbeelding 2 van 2
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: stap 3, afbeelding 1 van 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: stap 4, afbeelding 1 van 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: stap 4, afbeelding 2 van 2
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: stap 5, afbeelding 1 van 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: stap 5, afbeelding 2 van 2
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: stap 6, afbeelding 1 van 3 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: stap 6, afbeelding 2 van 3 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: stap 6, afbeelding 3 van 3
    • Disconnect ribbon tabs 1,2,5,8G, and 3.
    • Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
    • Then remove the plugs
  7. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: stap 7, afbeelding 1 van 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: stap 7, afbeelding 2 van 2
    • With the Phillips #00 screwdriver, remove the two Phillips screws.
  8. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: stap 8, afbeelding 1 van 1
    • Double check to make sure all tabs, plugs and screws are removed or disconnected.
    • Gently lift motherboard out of the case.
  9. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Power Button: stap 9, afbeelding 1 van 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Power Button: stap 9, afbeelding 2 van 2
    • Carefully remove the plastic. This will help you gain access to the power button panel.
  10. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: stap 10, afbeelding 1 van 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: stap 10, afbeelding 2 van 2
    • With a Phillips #00 screwdriver, remove the two screws on the power button panel.
  11. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: stap 11, afbeelding 1 van 1
    • Gently pull the power button out from the panel. Replace it with a new one.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 1,031
