Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Use this guide to replace the back con board of a DJI Phantom 4 Advanced Remote Controller.
With step by step detailed instructions, you will be able to safely resolve issues that may arise with the back con board.
  1. Remove the four screws with a Torx T8 screwdriver to access the back con board.
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. Remove three screws using a Phillips #00 screwdriver.
    • Remove three screws using a Phillips #00 screwdriver.
  3. With tweezers, gently remove the large con board tab. Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. Peel off the rubber grips to access the screw holes. Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. Pull apart the back plastic panel. Recommended tool for this would be the metal spudger, but not required.
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
Conclusie
cade knott
391 Reputatie
3 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 286
