Ga door naar hoofdinhoud
DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement
Wat je nodig hebt
  1. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: stap 2, afbeelding 1 van 2 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: stap 2, afbeelding 2 van 2
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: stap 3, afbeelding 1 van 2 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: stap 4, afbeelding 1 van 2 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: stap 4, afbeelding 2 van 2
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: stap 5, afbeelding 1 van 2 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: stap 5, afbeelding 2 van 2
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement, Back Con Board: stap 6, afbeelding 1 van 1
    • Remove the three PH0 screws securing the PCB to the remote.
  7. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: stap 7, afbeelding 1 van 2 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: stap 7, afbeelding 2 van 2
    • Remove each of the three ribbon cables from their tabs by pulling in a horizontal direction away from the socket.
    • Remove the Back Con Board.
  8. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: stap 8, afbeelding 1 van 1
    • The board can now be replaced.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 993
