Ga door naar hoofdinhoud
DJI Phantom 3 Advanced Landing Gear Replacement
Wat je nodig hebt
  1. DJI Phantom 3 Advanced Landing Gear Replacement, Battery: stap 1, afbeelding 1 van 2 DJI Phantom 3 Advanced Landing Gear Replacement, Battery: stap 1, afbeelding 2 van 2
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Landing Gear Replacement: stap 2, afbeelding 1 van 2 DJI Phantom 3 Advanced Landing Gear Replacement: stap 2, afbeelding 2 van 2
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: stap 3, afbeelding 1 van 3 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: stap 3, afbeelding 2 van 3 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: stap 3, afbeelding 3 van 3
    • Turn the phantom upside down.
    • Remove the eight 7.5mm long 3mm screws, securing the landing gear to the body of the quadcopter, with a T-8 screwdriver.
  4. DJI Phantom 3 Advanced Landing Gear Replacement: stap 4, afbeelding 1 van 3 DJI Phantom 3 Advanced Landing Gear Replacement: stap 4, afbeelding 2 van 3 DJI Phantom 3 Advanced Landing Gear Replacement: stap 4, afbeelding 3 van 3
    • Remove the rubber spacer in the landing gear by pushing the spacer out of the slot with your finger.
  5. DJI Phantom 3 Advanced Landing Gear Replacement: stap 5, afbeelding 1 van 3 DJI Phantom 3 Advanced Landing Gear Replacement: stap 5, afbeelding 2 van 3 DJI Phantom 3 Advanced Landing Gear Replacement: stap 5, afbeelding 3 van 3
    • Using a plastic opening tool, carefully separate the two pieces of plastic of the landing gear.
    • Be careful not to break the wire attached, as this is your receiver antenna.
  6. DJI Phantom 3 Advanced Landing Gear Replacement: stap 6, afbeelding 1 van 3 DJI Phantom 3 Advanced Landing Gear Replacement: stap 6, afbeelding 2 van 3 DJI Phantom 3 Advanced Landing Gear Replacement: stap 6, afbeelding 3 van 3
    • Feed the wire and attached plastic through the hole in the landing gear.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Quinn Tirpak
319 Reputatie
2 handleidingen geschreven
Cal Poly, Team 10-2, Livingston Fall 2016 Lid van Cal Poly, Team 10-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G2
3 Leden
12 handleidingen geschreven
Één opmerking
I have a single coax cable in my landing gear. the gear broke and the wire tore off the connector. How do I fix this?
Art - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 3,849
