Ga door naar hoofdinhoud
DJI Phantom 2 Vision Plus GPS Signal Improvement Technique
Wat je nodig hebt
Video overzicht
  1. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Case Top Shell: stap 1, afbeelding 1 van 2 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Case Top Shell: stap 1, afbeelding 2 van 2
    • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
  2. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique: stap 2, afbeelding 1 van 2 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique: stap 2, afbeelding 2 van 2
    • Gently lift up the top shell case.
    • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
  3. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: stap 3, afbeelding 1 van 3 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: stap 3, afbeelding 2 van 3 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: stap 3, afbeelding 3 van 3
    • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
    • Pull the GPS connector straight up out of its socket.
    • Lift the top shell case up and remove it from the body of the Phantom.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Sam Goldheart
465.647 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.732 handleidingen geschreven
3 opmerkingen
hello do you still help with phantom drones
George Aguirre - Antwoord
do you still help with drones/
Isn't it better to connect the aluminium foil to the GPS GND for better isolation?
Bruno Duarte - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 4,600
