Inleiding
Hi everyone, In this guide, I'll show you how to replace the motherboard on the DJI Mini 3 Pro drone.
After installing the motherboard, you will need to calibrate your drone. Some calibration processes can be done with the DJI Fly mobile app, but for some processes, like camera gimbal calibration, you will need to use additional software. How to calibrate the gimbal watch this video tutorial https://youtu.be/mu03HWXplM4
Wat je nodig hebt
Video-instructies
To reassemble your device, follow these instructions.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Only have 20 minutes on our new DJI Mini 3 pro. Crashed it into leaves on a tree. :( About a 20 foot fall to dirt. It still flew afterwards, but no cam. Gimbal stuck it said. Gimbal rubbers messed up and replaced. Also replace the gimbal cable because it was not acting right. Now it will not power on with charged batteries or even with the drone directly plugged in? NOTHING lights up on drone, no movement, acts 100% dead when I push the power button. Remove battery and can feel heat from inside under the boards? Never got wet. Any ideas? Thanks in advance. Going on vacation in 3 days and was in hopes of fixing it. I can not find a replacement mother board if that is my issue?
hemitwist - Antwoord
