Ga door naar hoofdinhoud
DJI Mavic Pro Upper Shell Replacement
Wat je nodig hebt
  1. DJI Mavic Pro Upper Shell Replacement, Battery: stap 1, afbeelding 1 van 3 DJI Mavic Pro Upper Shell Replacement, Battery: stap 1, afbeelding 2 van 3 DJI Mavic Pro Upper Shell Replacement, Battery: stap 1, afbeelding 3 van 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Upper Shell Replacement, Upper Shell: stap 2, afbeelding 1 van 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Upper Shell Replacement: stap 3, afbeelding 1 van 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro Upper Shell Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro Upper Shell Replacement: stap 5, afbeelding 1 van 1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro Upper Shell Replacement: stap 6, afbeelding 1 van 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro Upper Shell Replacement: stap 7, afbeelding 1 van 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Mondona Behroozian
1.567 Reputatie
2 handleidingen geschreven
Cal Poly, Team S17-G3, White Fall 2018 Lid van Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Leden
14 handleidingen geschreven
2 opmerkingen
Well done, good instructions - are the two screws under the tabs shorter than the others from the shell?
Lazaro Hernandez - Antwoord
Awesome descriptions were perfect except for saying there is 4 acres to be removed under the tabs behind the gimbal. Theirs only 2
shaun.cunningham - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 64
Altijd: 5,295
