Inleiding
This set of instructions will walk you through the removal process of the DJI Mavic Pro GPS Module. You will first need to remove the battery and then the upper shell before you can get to the GPS Module. Be aware when going through the removal of the module that you may hear a popping sound; don't be alarmed as this is normal.
Wat je nodig hebt
Grab both sides of the battery.
Pinch the releasing buttons on both sides of the battery.
Lift the battery up and out.
Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
Flip the upper shell over so the metallic plate is facing up.
Remove the two 5mm JIS #00 screws from the metallic plate by turning the screwdriver counterclockwise.
8 andere personen hebben deze handleiding voltooid.
