Ga door naar hoofdinhoud
DJI Mavic Pro GPS Module Replacement
Wat je nodig hebt
  1. DJI Mavic Pro GPS Module Replacement, Battery: stap 1, afbeelding 1 van 3 DJI Mavic Pro GPS Module Replacement, Battery: stap 1, afbeelding 2 van 3 DJI Mavic Pro GPS Module Replacement, Battery: stap 1, afbeelding 3 van 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro GPS Module Replacement, Upper Shell: stap 2, afbeelding 1 van 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro GPS Module Replacement: stap 3, afbeelding 1 van 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro GPS Module Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro GPS Module Replacement: stap 5, afbeelding 1 van 1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro GPS Module Replacement: stap 6, afbeelding 1 van 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro GPS Module Replacement: stap 7, afbeelding 1 van 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro GPS Module Replacement, GPS Module: stap 8, afbeelding 1 van 1
    • Flip the upper shell over so the metallic plate is facing up.
    • Remove the two 5mm JIS #00 screws from the metallic plate by turning the screwdriver counterclockwise.
    • If the JIS #00 screwdriver is too small, you may need to use a JIS #0 screwdriver.
  9. DJI Mavic Pro GPS Module Replacement: stap 9, afbeelding 1 van 1
    • Pry the metallic plate up from the upper shell by using a nylon spudger.
    • Remove the metallic plate from the upper shell by lifting the plate up and out.
    • You may hear a popping sound when prying the metallic plate, but no damage will occur.
  10. DJI Mavic Pro GPS Module Replacement: stap 10, afbeelding 1 van 1
    Koop
    • Use tweezers to remove the GPS Module from the upper shell.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Kyle Kelser
598 Reputatie
2 handleidingen geschreven
Cal Poly, Team S17-G3, White Fall 2018 Lid van Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 86
Altijd: 8,850
