Ga door naar hoofdinhoud
DJI Mavic Pro Front Vision Replacement
Wat je nodig hebt
  1. DJI Mavic Pro Front Vision Replacement, Battery: stap 1, afbeelding 1 van 3 DJI Mavic Pro Front Vision Replacement, Battery: stap 1, afbeelding 2 van 3 DJI Mavic Pro Front Vision Replacement, Battery: stap 1, afbeelding 3 van 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Front Vision Replacement, Upper Shell: stap 2, afbeelding 1 van 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Front Vision Replacement: stap 3, afbeelding 1 van 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro Front Vision Replacement: stap 4, afbeelding 1 van 1
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro Front Vision Replacement: stap 5, afbeelding 1 van 1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro Front Vision Replacement: stap 6, afbeelding 1 van 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro Front Vision Replacement: stap 7, afbeelding 1 van 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro Front Vision Replacement, Gimbal/Camera: stap 8, afbeelding 1 van 1
    • Remove the one 5mm JIS #0 screw from the small micro controller board at the front of the DJI Mavic Pro by turning counterclockwise.
  9. DJI Mavic Pro Front Vision Replacement: stap 9, afbeelding 1 van 1
    • Pull the cord and micro controller board away from the front of the DJI Mavic Pro using tweezers.
  10. DJI Mavic Pro Front Vision Replacement: stap 10, afbeelding 1 van 2 DJI Mavic Pro Front Vision Replacement: stap 10, afbeelding 2 van 2
    • Expose the two small ZIF connectors near the front of the board by removing the plastic coverings.
    • Then, remove the two ZIF connectors under the coverings using a nylon spudger.
  11. DJI Mavic Pro Front Vision Replacement: stap 11, afbeelding 1 van 1
    • Remove two 6mm JIS #00 screws from the plastic board cover at the front of the DJI Mavic Pro.
  12. DJI Mavic Pro Front Vision Replacement: stap 12, afbeelding 1 van 2 DJI Mavic Pro Front Vision Replacement: stap 12, afbeelding 2 van 2
    • Flip the DJI Mavic Pro over.
    • Gently press the latch for the Gimbal cover.
    • Pull the cover off.
  13. DJI Mavic Pro Front Vision Replacement: stap 13, afbeelding 1 van 2 DJI Mavic Pro Front Vision Replacement: stap 13, afbeelding 2 van 2
    • Flip the DJI Mavic Pro back over, with its top side facing up.
    • Remove the two ZIF connectors located behind the plastic covers by using a nylon spudger.
  14. DJI Mavic Pro Front Vision Replacement: stap 14, afbeelding 1 van 1
    • Gently remove the power cable connector located to the left, behind the gimbal board, by pulling up on the white base.
  15. DJI Mavic Pro Front Vision Replacement: stap 15, afbeelding 1 van 1
    • Scrape away the plastic adhesive covering the two 5mm JIS #000 screws connected to the gimbal board.
    • Remove the two 5mm JIS #000 screws from the gimbal board by turning the screwdriver counterclockwise.
  16. DJI Mavic Pro Front Vision Replacement: stap 16, afbeelding 1 van 1
    • Remove the two 7mm JIS #00 screws at the very front of the DJI Mavic Pro by turning the screwdriver counterclockwise.
    • Careful when removing these screws the camera or whatever remains of your camera assembly may drop
  17. DJI Mavic Pro Front Vision Replacement: stap 17, afbeelding 1 van 2 DJI Mavic Pro Front Vision Replacement: stap 17, afbeelding 2 van 2
    • Flip the DJI Mavic Pro over, with the camera facing you.
    • Gently pull the gimbal/camera assembly up and out.
  18. DJI Mavic Pro Front Vision Replacement, Front Vision: stap 18, afbeelding 1 van 1
    • Remove the two 6mm JIS #0 screws by turning counterclockwise.
  19. DJI Mavic Pro Front Vision Replacement: stap 19, afbeelding 1 van 1
    • Remove the front vision piece by pulling the piece up and away from the drone body.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Kyle Kelser
592 Reputatie
2 handleidingen geschreven
Cal Poly, Team S17-G3, White Fall 2018 Lid van Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Leden
14 handleidingen geschreven
Één opmerking
What error codes did you get before having to replace this front cameras?
Daniel Rubio Rocamora - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 54
Altijd: 6,662
