Ga door naar hoofdinhoud
DJI Mavic Mini Propellers Replacement
Wat je nodig hebt
  1. DJI Mavic Mini Propellers Replacement, Propellers: stap 1, afbeelding 1 van 3 DJI Mavic Mini Propellers Replacement, Propellers: stap 1, afbeelding 2 van 3 DJI Mavic Mini Propellers Replacement, Propellers: stap 1, afbeelding 3 van 3
    • Place the DJI Mavic Mini on a flat surface with the props oriented upwards.
    • For ease of access place the prop arms in the "open" position.
  2. DJI Mavic Mini Propellers Replacement: stap 2, afbeelding 1 van 3 DJI Mavic Mini Propellers Replacement: stap 2, afbeelding 2 van 3 DJI Mavic Mini Propellers Replacement: stap 2, afbeelding 3 van 3
    • Remove the 2.4 mm J000 screw from the damaged propeller.
    • When removing the screws, you may need to apply some pressure to the swivel mount that holds the propellers.
    • Remove the damaged propellers.
  3. DJI Mavic Mini Propellers Replacement: stap 3, afbeelding 1 van 2 DJI Mavic Mini Propellers Replacement: stap 3, afbeelding 2 van 2
    • Keep the 2.4 mm J000 screw from the damaged propeller to use again when fastening on the replacement.
    • While one or both propellers are removed for replacement, it is recommended that you inspect the exposed swivel mount for any debris which may impact drone performance.
    • Additionally, when fastening the replacement propeller make sure that the screw is inserted into the interior hole on the swivel mount.
Conclusie
Chase Smith
147 Reputatie
1 Handleiding geschreven
Clemson, Team 1-2, Hunter Spring 2022 Lid van Clemson, Team 1-2, Hunter Spring 2022
CLEM-HUNTER-S22S1G2
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 36
Altijd: 899
