Inleiding
Is your DJI Mavic Mini experiencing trouble with positioning, stability, or returning home? Many of these problems an be due to weak signals or a faulty GPS. In this set of instructions, we will detail the removal process, inspection, and replacement of the DJI Mavic Mini GPS Module.
Before starting this repair, turn off the device and remove the battery.
Wat je nodig hebt
Orient the DJI Mavic Mini so that the camera faces away.
Use your finger to depress the lip on the panel until the lid becomes ajar.
Flip the panel up to expose the battery module.
Put your fingers against edge of the top case and begin undoing the connections at the edges first, then proceed to pry it open.
Alternatively, you may insert the iFixit opening tool between the top and bottom case first, and work your way around the perimeter to detach the top case.
