Ga door naar hoofdinhoud
DJI Mavic Mini Battery Replacement
  1. DJI Mavic Mini Battery Replacement, Battery: stap 1, afbeelding 1 van 2 DJI Mavic Mini Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Orient the DJI Mavic Mini so that the camera faces away.
    • Use your finger to depress the lip on the panel until the lid becomes ajar.
    • Flip the panel up to expose the battery module.
  2. DJI Mavic Mini Battery Replacement: stap 2, afbeelding 1 van 2 DJI Mavic Mini Battery Replacement: stap 2, afbeelding 2 van 2
    • Depress the locking mechanism on the battery module to release the lock.
    • Pull the battery straight out of the casing.
  3. DJI Mavic Mini Battery Replacement: stap 3, afbeelding 1 van 2 DJI Mavic Mini Battery Replacement: stap 3, afbeelding 2 van 2
    • Check the battery pins on the DJI Drone for corrosion or warping. If either of these conditions are present, replacing the battery module may not help resolve the issue at hand.
    • Check the pin receptacles on the battery module for blockages.
    • Insert a new battery into the casing. Ensure that all connections are clean, unobstructed, and straight.
Conclusie
Is your DJI Mavic Mini experiencing trouble with positioning, stability, or returning to home? Many of these problems an be due to weak signals or a faulty GPS. In this set of instructions, we will detail the removal process, inspection, and replacement of the DJI Mavic Mini GPS Module.
Cooper Schroeder
263 Reputatie
2 handleidingen geschreven
Clemson, Team 1-2, Hunter Spring 2022 Lid van Clemson, Team 1-2, Hunter Spring 2022
CLEM-HUNTER-S22S1G2
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 1,251
