Ga door naar hoofdinhoud
DBPOWER T20 Speaker Replacement
Wat je nodig hebt
  1. DBPOWER T20 Speaker Replacement, DBPOWER T20 Disassembly: stap 1, afbeelding 1 van 1
    • Flip the device and lay flat.
  2. DBPOWER T20 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Speaker Replacement: stap 3, afbeelding 1 van 3 DBPOWER T20 Speaker Replacement: stap 3, afbeelding 2 van 3 DBPOWER T20 Speaker Replacement: stap 3, afbeelding 3 van 3
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Speaker Replacement: stap 5, afbeelding 1 van 2 DBPOWER T20 Speaker Replacement: stap 5, afbeelding 2 van 2
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Speaker Replacement: stap 6, afbeelding 1 van 3 DBPOWER T20 Speaker Replacement: stap 6, afbeelding 2 van 3 DBPOWER T20 Speaker Replacement: stap 6, afbeelding 3 van 3
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Speaker Replacement: stap 7, afbeelding 1 van 2 DBPOWER T20 Speaker Replacement: stap 7, afbeelding 2 van 2
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Speaker Replacement: stap 8, afbeelding 1 van 1
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Speaker Replacement: stap 9, afbeelding 1 van 2 DBPOWER T20 Speaker Replacement: stap 9, afbeelding 2 van 2
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Speaker Replacement: stap 10, afbeelding 1 van 2 DBPOWER T20 Speaker Replacement: stap 10, afbeelding 2 van 2
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Speaker Replacement, Speaker: stap 11, afbeelding 1 van 2 DBPOWER T20 Speaker Replacement, Speaker: stap 11, afbeelding 2 van 2
    • Remove the two (3 mm) screws connecting the bracket down and pull out the reflector, using a J0 Philips Head Screwdriver.
  12. DBPOWER T20 Speaker Replacement: stap 12, afbeelding 1 van 3 DBPOWER T20 Speaker Replacement: stap 12, afbeelding 2 van 3 DBPOWER T20 Speaker Replacement: stap 12, afbeelding 3 van 3
    • Slide the mirror straight up to remove.
  13. DBPOWER T20 Speaker Replacement: stap 13, afbeelding 1 van 3 DBPOWER T20 Speaker Replacement: stap 13, afbeelding 2 van 3 DBPOWER T20 Speaker Replacement: stap 13, afbeelding 3 van 3
    • Slide out the power source and disconnect its cables from the power jack and the light.
  14. DBPOWER T20 Speaker Replacement: stap 14, afbeelding 1 van 3 DBPOWER T20 Speaker Replacement: stap 14, afbeelding 2 van 3 DBPOWER T20 Speaker Replacement: stap 14, afbeelding 3 van 3
    • Remove the screws holding down the first speaker with a J0 screwdriver.
    • Remove the screws holding down the second speaker down.
Conclusie
Ryan Goldin
245 Reputatie
1 Handleiding geschreven
USF Tampa, Team S16-G2, Boczar Spring 2018 Lid van USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 437
