Inleiding
Simply pull the lamp out once you remove the screws. This should not require much force so if the lamp is not coming out, make sure you took out all the screws in the steps leading up to the removal.
Wat je nodig hebt
Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
one of the screws have been stripped, I’ve tried the rubber band and the glue trick, it didn’t work. What do I do to remove it? please respond
4 andere personen hebben deze handleiding voltooid.
6 opmerkingen
The part that is being removed is NOT the LED lamp. My interest is replacing the actual LED lamp that sits behind the plastic part that is being removed. My projector image started to have a tan cast to it near the top left portion of the screen due to overheating. I am just assuming that it is the actual LED that is overheating and need replacing. The article is very good otherwise. Please add where replacement parts can be obtained.
Thank you very much, I appreciate the ability to get a look without having to open it up
Where can i buy the lamp?
Merci pour ce tuto! =) ça ma permis de nettoyer la lentille qui était pleine de poussière!
For those looking for the LED bulb for this projector, it's not a regular projector bulb. As others have pointed out, this tutorial, as great as it is, onlly shows the removal of the plastic cover which holds a reflector. The actual bulb is a surface mount Bridgelux LED chip, 6x12 micro bulb grid. There are no part numbers on the assembly, but I was able to find similar led chips on AliExpress and eBay. Frankly, for the price of the replacement, it's not likely worth the expense. :-(
Also, to add - the polarized glass piece suffers from burn-in after prolonged use, so if you see a brownish spot, it's the glass, not the bulb. Being a custom piece, it will be very difficult to replace unless an OEM preplacement is found.
