Ga door naar hoofdinhoud
DBPOWER RD-810 Lens Replacement
Wat je nodig hebt
  1. DBPOWER RD-810 Lens Replacement, Top Cover: stap 1, afbeelding 1 van 2 DBPOWER RD-810 Lens Replacement, Top Cover: stap 1, afbeelding 2 van 2
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Lens Replacement: stap 2, afbeelding 1 van 1
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Lens Replacement, Motherboard and LED Bulb: stap 3, afbeelding 1 van 3 DBPOWER RD-810 Lens Replacement, Motherboard and LED Bulb: stap 3, afbeelding 2 van 3 DBPOWER RD-810 Lens Replacement, Motherboard and LED Bulb: stap 3, afbeelding 3 van 3
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Lens Replacement: stap 4, afbeelding 1 van 3 DBPOWER RD-810 Lens Replacement: stap 4, afbeelding 2 van 3 DBPOWER RD-810 Lens Replacement: stap 4, afbeelding 3 van 3
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Lens Replacement: stap 5, afbeelding 1 van 3 DBPOWER RD-810 Lens Replacement: stap 5, afbeelding 2 van 3 DBPOWER RD-810 Lens Replacement: stap 5, afbeelding 3 van 3
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Lens Replacement, Power Supply Circuit: stap 6, afbeelding 1 van 3 DBPOWER RD-810 Lens Replacement, Power Supply Circuit: stap 6, afbeelding 2 van 3 DBPOWER RD-810 Lens Replacement, Power Supply Circuit: stap 6, afbeelding 3 van 3
    • Remove the two 9mm PH2 phillips head screws.
    • Lift the mirror behind the power supply circuit out to gain access to the circuit board.
  7. DBPOWER RD-810 Lens Replacement: stap 7, afbeelding 1 van 2 DBPOWER RD-810 Lens Replacement: stap 7, afbeelding 2 van 2
    • Lift the power supply circuit board out of the projector.
    • Disconnect the cable connector by pulling the two sides of the connector apart.
    • Keep the connector parallel to the circuit board to avoid breaking the solder connection.
  8. DBPOWER RD-810 Lens Replacement, Lens: stap 8, afbeelding 1 van 3 DBPOWER RD-810 Lens Replacement, Lens: stap 8, afbeelding 2 van 3 DBPOWER RD-810 Lens Replacement, Lens: stap 8, afbeelding 3 van 3
    • Flip the projector over and remove the two 6mm PH2 phillips head screws.
    • Flip the projector over so that the opening is facing up.
    • Lift the lens up slightly and then move it towards the interior of the projector before lifting it up and out of the way.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
John Russell
941 Reputatie
9 handleidingen geschreven
USF Tampa, Team S5-G3, Eyestone Spring 2018 Lid van USF Tampa, Team S5-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S5G3
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 627
