Ga door naar hoofdinhoud
DBPOWER RD-810 Fan Replacement
Wat je nodig hebt
  1. DBPOWER RD-810 Fan Replacement, Top Cover: stap 1, afbeelding 1 van 2 DBPOWER RD-810 Fan Replacement, Top Cover: stap 1, afbeelding 2 van 2
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Fan Replacement: stap 2, afbeelding 1 van 1
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Fan Replacement, Motherboard and LED Bulb: stap 3, afbeelding 1 van 3 DBPOWER RD-810 Fan Replacement, Motherboard and LED Bulb: stap 3, afbeelding 2 van 3 DBPOWER RD-810 Fan Replacement, Motherboard and LED Bulb: stap 3, afbeelding 3 van 3
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Fan Replacement: stap 4, afbeelding 1 van 3 DBPOWER RD-810 Fan Replacement: stap 4, afbeelding 2 van 3 DBPOWER RD-810 Fan Replacement: stap 4, afbeelding 3 van 3
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Fan Replacement: stap 5, afbeelding 1 van 3 DBPOWER RD-810 Fan Replacement: stap 5, afbeelding 2 van 3 DBPOWER RD-810 Fan Replacement: stap 5, afbeelding 3 van 3
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Fan Replacement, Fan: stap 6, afbeelding 1 van 1
    • Lift the fan up and out of the projector.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
John Russell
914 Reputatie
9 handleidingen geschreven
USF Tampa, Team S5-G3, Eyestone Spring 2018 Lid van USF Tampa, Team S5-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S5G3
3 Leden
2 opmerkingen
Wich cooler does fit ? I just bought the Projector and want to change the Fan because it is too loud
pr0mqu33nkill3r - Antwoord
Do you know the fan size / model? I bought one of these projectors but the fan is way to loud. I want to replace it for a quiet one
Luis - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 710
