Ga door naar hoofdinhoud
D-Link HD Wi-Fi Camera Microphone Replacement
Wat je nodig hebt
  1. D-Link HD Wi-Fi Camera Microphone Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link HD Wi-Fi Camera Microphone Replacement: stap 2, afbeelding 1 van 2 D-Link HD Wi-Fi Camera Microphone Replacement: stap 2, afbeelding 2 van 2
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link HD Wi-Fi Camera Microphone Replacement: stap 3, afbeelding 1 van 2 D-Link HD Wi-Fi Camera Microphone Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
  4. D-Link HD Wi-Fi Camera Microphone Replacement, Microphone: stap 4, afbeelding 1 van 1
    • To remove the front cover, place index finger in the center and pull away from the frame. This may take a little effort, but should not require an opening tool.
  5. D-Link HD Wi-Fi Camera Microphone Replacement: stap 5, afbeelding 1 van 2 D-Link HD Wi-Fi Camera Microphone Replacement: stap 5, afbeelding 2 van 2
    • After the cover is removed, unscrew the two Phillips #00 5.0mm screws. Then the board should slide right out.
Conclusie
Morgen Jaques
533 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 490
