Ga door naar hoofdinhoud
D-Link EBR-2310 Motherboard Replacement
Wat je nodig hebt
  1. D-Link EBR-2310 Motherboard Replacement, Remove Plastic Screw Coverings: stap 1, afbeelding 1 van 1
    • Begin by placing the wired router face down.
    • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
    • The two bottom plastic screw coverings do not need to be taken off.
  2. D-Link EBR-2310 Motherboard Replacement, Remove Screws: stap 2, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the two top screws.
  3. D-Link EBR-2310 Motherboard Replacement, Pry Open The Router: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool between the edges of the router and gently pry the device apart.
    • Release the clips as you work your way around the device to avoid breaking them.
    • Separate the front and back case of the router.
  4. D-Link EBR-2310 Motherboard Replacement, Remove Silver Casing: stap 4, afbeelding 1 van 2 D-Link EBR-2310 Motherboard Replacement, Remove Silver Casing: stap 4, afbeelding 2 van 2
    • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
    • It should easily snap out of place.
  5. D-Link EBR-2310 Motherboard Replacement, Remove Inner Bottom Screws: stap 5, afbeelding 1 van 2 D-Link EBR-2310 Motherboard Replacement, Remove Inner Bottom Screws: stap 5, afbeelding 2 van 2
    • Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
  6. D-Link EBR-2310 Motherboard Replacement, Remove Bottom Case: stap 6, afbeelding 1 van 1
    • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
    • You have now removed the logic board from your device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jessica
428 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 839
