Ga door naar hoofdinhoud
D-Link EBR-2310 LED Light Replacement
Wat je nodig hebt
  1. D-Link EBR-2310 LED Light Replacement, Remove Plastic Screw Coverings: stap 1, afbeelding 1 van 1
    • Begin by placing the wired router face down.
    • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
    • The two bottom plastic screw coverings do not need to be taken off.
  2. D-Link EBR-2310 LED Light Replacement, Remove Screws: stap 2, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the two top screws.
  3. D-Link EBR-2310 LED Light Replacement, Pry Open The Router: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool between the edges of the router and gently pry the device apart.
    • Release the clips as you work your way around the device to avoid breaking them.
    • Separate the front and back case of the router.
  4. D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: stap 4, afbeelding 1 van 2 D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: stap 4, afbeelding 2 van 2
    • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
    • It should easily snap out of place.
  5. D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: stap 5, afbeelding 1 van 2 D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: stap 5, afbeelding 2 van 2
    • Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
  6. D-Link EBR-2310 LED Light Replacement, Remove Bottom Case: stap 6, afbeelding 1 van 1
    • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
    • You have now removed the logic board from your device.
  7. D-Link EBR-2310 LED Light Replacement, Locate Problematic LED light: stap 7, afbeelding 1 van 1
    • Locate the problematic LED light on the motherboard.
    • Using a plastic opening tool, very gently tilt its black base backwards.
  8. D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: stap 8, afbeelding 1 van 2 D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: stap 8, afbeelding 2 van 2
    • Using your soft finger, tilt the LED light base backwards so that the actual light is facing upside down, at a 180 degree angle from the others.
  9. D-Link EBR-2310 LED Light Replacement, Remove the LED Light: stap 9, afbeelding 1 van 1
    • With a pair of tweezers, gently pry the LED light back and forth between its connecting wires until it is able to be removed.
  10. D-Link EBR-2310 LED Light Replacement, Complete Removal: stap 10, afbeelding 1 van 1
    • You should now have a removed LED light, ready to be replaced with a new one.
Conclusie
Jessica
428 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 353
