Ga door naar hoofdinhoud
D-Link DCS-825L LED Light Cover Replacement
Wat je nodig hebt
  1. D-Link DCS-825L LED Light Cover Replacement, Accent Ring: stap 1, afbeelding 1 van 1
    • Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
  2. D-Link DCS-825L LED Light Cover Replacement: stap 2, afbeelding 1 van 1
    • Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
  3. D-Link DCS-825L LED Light Cover Replacement: stap 3, afbeelding 1 van 1
    • Replace your accent ring with whichever color you choose.
  4. D-Link DCS-825L LED Light Cover Replacement, Back Casing: stap 4, afbeelding 1 van 2 D-Link DCS-825L LED Light Cover Replacement, Back Casing: stap 4, afbeelding 2 van 2
    • Remove one Phillips #2 screw from each side of the camera lens.
  5. D-Link DCS-825L LED Light Cover Replacement: stap 5, afbeelding 1 van 3 D-Link DCS-825L LED Light Cover Replacement: stap 5, afbeelding 2 van 3 D-Link DCS-825L LED Light Cover Replacement: stap 5, afbeelding 3 van 3
    • Pull the Wi-Fi Baby Camera open.
    • It should be easily done after the screws are removed.
  6. D-Link DCS-825L LED Light Cover Replacement: stap 6, afbeelding 1 van 2 D-Link DCS-825L LED Light Cover Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
  7. D-Link DCS-825L LED Light Cover Replacement: stap 7, afbeelding 1 van 3 D-Link DCS-825L LED Light Cover Replacement: stap 7, afbeelding 2 van 3 D-Link DCS-825L LED Light Cover Replacement: stap 7, afbeelding 3 van 3
    • Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
  8. D-Link DCS-825L LED Light Cover Replacement, LED Light Cover: stap 8, afbeelding 1 van 1
    • Grab the white cylinder with your thumb and index finger.
  9. D-Link DCS-825L LED Light Cover Replacement: stap 9, afbeelding 1 van 1
    • Gently lift the cylinder up from its placement in your Wi-Fi Baby Camera.
  10. D-Link DCS-825L LED Light Cover Replacement: stap 10, afbeelding 1 van 1
    • Remove the white cylinder completely to replace it.
Conclusie
Annalise Leclair
97 Reputatie
1 Handleiding geschreven
USF Tampa, Team S1-G5, Leahy Fall 2018 Lid van USF Tampa, Team S1-G5, Leahy Fall 2018
USFT-LEAHY-F18S1G5
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 317
