Ga door naar hoofdinhoud
D-Link DCS-5222L Motherboard Replacement
Wat je nodig hebt
  1. D-Link DCS-5222L Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 D-Link DCS-5222L Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the four rubber feet on the bottom of the camera using your fingers or a pair of tweezers.
  2. D-Link DCS-5222L Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Using a #1 Phillips screwdriver, remove the four 7mm screws that are exposed by the removed feet.
  3. D-Link DCS-5222L Motherboard Replacement: stap 3, afbeelding 1 van 2 D-Link DCS-5222L Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Using your hands, open the camera body by wiggling the bottom free from the upper shell.
    • Open the shell carefully, as the motherboard is attached to the bottom of the body; all of the components in the upper body are accordingly connected to the bottom. Likewise, the WiFi antenna is mounted to the upper shell, but a wire connects it to the motherboard on the bottom of the body.
  4. D-Link DCS-5222L Motherboard Replacement: stap 4, afbeelding 1 van 3 D-Link DCS-5222L Motherboard Replacement: stap 4, afbeelding 2 van 3 D-Link DCS-5222L Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Disconnect the five quick connections attaching the various cables to the motherboard with your fingers or blunt ended tweezers.
  5. D-Link DCS-5222L Motherboard Replacement: stap 5, afbeelding 1 van 2 D-Link DCS-5222L Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Using your soldering iron, heat the antenna contacts on the motherboard until the wire releases.
    • Soldering Irons are hot and can burn you and ignite flammable materials.
  6. D-Link DCS-5222L Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Using a #1 Phillips screwdriver, remove the single 7mm screw holding the motherboard in place.
  7. D-Link DCS-5222L Motherboard Replacement: stap 7, afbeelding 1 van 3 D-Link DCS-5222L Motherboard Replacement: stap 7, afbeelding 2 van 3 D-Link DCS-5222L Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Wiggle free the motherboard from the bottom of the body.
    • There are two pegs that limit the motherboard's rotation. Have some patience when wiggling it free.
    • The power and ethernet ports have ledges along their top surface. These must be removed from the body at an angle relative to the horizontal.
Conclusie
Ryan Null
377 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S2-G5, Peak Fall 2018 Lid van UMass Dartmouth, Team S2-G5, Peak Fall 2018
UMASSD-PEAK-F18S2G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 31
Altijd: 1,099
