Ga door naar hoofdinhoud
D-Link DCS-2630L Wi-Fi Camera Microphone Replacement
Wat je nodig hebt
  1. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Back casing: stap 1, afbeelding 1 van 1
    • Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
  2. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: stap 2, afbeelding 1 van 1
    • Remove the back casing to expose the circuit board.
  3. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: stap 3, afbeelding 1 van 1
    • Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
  4. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: stap 4, afbeelding 1 van 1
    • Detach the speaker wire by gently pulling on the side closest to the body of the camera.
  5. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Microphone: stap 5, afbeelding 1 van 1
    • Remove the two 4.35 mm screws on the circuit board using the Philips head PH00 screw driver.
  6. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: stap 6, afbeelding 1 van 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: stap 6, afbeelding 2 van 2
    • Detach the white plug by gently pulling on the black wires.
  7. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: stap 7, afbeelding 1 van 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: stap 7, afbeelding 2 van 2
    • Remove the circuit board to expose the camera body.
    • At the same time, you will need to feed the wires through the circuit board and out the slot in the black plate under the circuit board.
  8. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: stap 8, afbeelding 1 van 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: stap 8, afbeelding 2 van 2
    • Gently pull on the grey wire to detach the microphone from the camera body.
  9. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: stap 9, afbeelding 1 van 3 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: stap 9, afbeelding 2 van 3 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: stap 9, afbeelding 3 van 3
    • Detach the microphone from the circuit board by gently pulling on the grey wire.
Conclusie
Stanley DeLuna-Dabrowski
133 Reputatie
1 Handleiding geschreven
IUPUI, Team S4-G2, Baechle Spring 2018 Lid van IUPUI, Team S4-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G2
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 15
Altijd: 402
