Ga door naar hoofdinhoud
D-Link HD Wi-Fi Camera Motherboard Replacement
Wat je nodig hebt
  1. D-Link   HD Wi-Fi Camera Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link   HD Wi-Fi Camera Motherboard Replacement: stap 2, afbeelding 1 van 2 D-Link   HD Wi-Fi Camera Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link   HD Wi-Fi Camera Motherboard Replacement: stap 3, afbeelding 1 van 2 D-Link   HD Wi-Fi Camera Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
Conclusie
Morgen Jaques
533 Reputatie
5 handleidingen geschreven
Één opmerking
Where can I get the replacement motherboard? Been trying to search online, but to no avail.
Azlin Rahim - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 868
