Inleiding
The membrane keys on the keyboard may become stuck or cease functioning due to wear or improper maintenance. This guide will show how to replace keys that have stopped functioning.
Wat je nodig hebt
Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
Remove the metal backing located directly underneath the white plastic casing.
Now the cell membrane should be exposed, gently lift this part and ensure that the rubber buffers are all intact to the membrane, if not pick up the buffers and set to the side.
Één andere persoon heeft deze handleiding voltooid.
