Ga door naar hoofdinhoud
CyberPowerPC Fangbook MS-1763 Battery Replacement
Wat je nodig hebt
  1. CyberPowerPC Fangbook MS-1763 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Save all of your work and turn off the laptop before beginning.
    • Close the laptop and flip it so that the bottom side is facing up.
    • Locate the battery compartment.
  2. CyberPowerPC Fangbook MS-1763 Battery Replacement: stap 2, afbeelding 1 van 1
    • Pull the latches away from the battery compartment. The lid of the compartment should pop out of place.
  3. CyberPowerPC Fangbook MS-1763 Battery Replacement: stap 3, afbeelding 1 van 1
    • Tilt the lid so that it leans away from the laptop and exposes the battery below.
    • Remove the battery from the newly opened compartment.
Conclusie
Insert a new battery and close the compartment lid to complete.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
what is the battery name?
Jimmy Grant - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 1,062
