Ga door naar hoofdinhoud
CyberPower UPS Battery Replacement
Wat je nodig hebt
  1. CyberPower UPS Battery Replacement, Battery: stap 1, afbeelding 1 van 2 CyberPower UPS Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Power down the unit by pressing the power button until the display goes black.
    • This is usually about 3 seconds.
    • Unplug the power cord from the wall outlet.
  2. CyberPower UPS Battery Replacement: stap 2, afbeelding 1 van 3 CyberPower UPS Battery Replacement: stap 2, afbeelding 2 van 3 CyberPower UPS Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove the battery plate cover at the bottom of the UPS using a Phillips #1 screwdriver.
    • If the screwdriver is not magnetized, tap on the cover plate to completely remove the screw.
  3. CyberPower UPS Battery Replacement: stap 3, afbeelding 1 van 2 CyberPower UPS Battery Replacement: stap 3, afbeelding 2 van 2
    • Slide the battery cover plate to the left.
    • Grasp the battery plate cover and lift it off the the UPS.
  4. CyberPower UPS Battery Replacement: stap 4, afbeelding 1 van 3 CyberPower UPS Battery Replacement: stap 4, afbeelding 2 van 3 CyberPower UPS Battery Replacement: stap 4, afbeelding 3 van 3
    • Pull out the battery to expose the terminal connectors.
    • Use needlenose pliers to disconnect both battery terminal connectors.
    • Do not pull the connectors by the wires, pull connectors by grabbing the connector itself.
    • With the battery terminal connectors disconnected, slide the battery all the way out.
  5. CyberPower UPS Battery Replacement: stap 5, afbeelding 1 van 3 CyberPower UPS Battery Replacement: stap 5, afbeelding 2 van 3 CyberPower UPS Battery Replacement: stap 5, afbeelding 3 van 3
    • The replacement battery should be a 12 volt, 9 amp-hour, sealed lead acid battery with f2 type connectors.
    • Install the new battery and reconnect the terminals.
  6. CyberPower UPS Battery Replacement: stap 6, afbeelding 1 van 3 CyberPower UPS Battery Replacement: stap 6, afbeelding 2 van 3 CyberPower UPS Battery Replacement: stap 6, afbeelding 3 van 3
    • Insert the screw to secure the battery cover plate.
    • Tighten the screw with a Phillips #1 screwdriver.
  7. CyberPower UPS Battery Replacement: stap 7, afbeelding 1 van 3 CyberPower UPS Battery Replacement: stap 7, afbeelding 2 van 3 CyberPower UPS Battery Replacement: stap 7, afbeelding 3 van 3
    • Plug system into the wall outlet.
    • Press the power button to turn on the unit.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jervon Stuart
169 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 67
Afgelopen 30 dagen: 314
Altijd: 12,664
