Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Removing the back panel requires taking of the top panel first. Then, you must remove four more screws on the back.
Onderdelen
Geen onderdelen opgegeven.
  1. Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD. Unplug the DVD player from the wall socket.
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
  2. Remove the top panel of the DVD Player by: Sliding the top panel backwards.
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
  3. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  4. Remove the remaining screws on the back of the DVD player: There will be four 15 mm screws and two 6.3 mm screws.
    • Remove the remaining screws on the back of the DVD player:
    • There will be four 15 mm screws and two 6.3 mm screws.
  5. Remove the back panel by:
    • Remove the back panel by:
    • Lifting up on the back panel.
    • Pulling the back panel backwards from the DVD player.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Chris Menezes
630 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-5, Forte Spring 2014 Lid van Cal Poly, Team 6-5, Forte Spring 2014
CPSU-FORTE-S14S6G5
5 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 368
