Ga door naar hoofdinhoud
Cyber-Shot DSC-H55 Battery Replacement
  1. Cyber-Shot DSC-H55 Battery Replacement, Finding the battery compartment: stap 1, afbeelding 1 van 2 Cyber-Shot DSC-H55 Battery Replacement, Finding the battery compartment: stap 1, afbeelding 2 van 2
    • Before you begin it is important to know where the battery compartment is. The battery compartment is located on the bottom of the camera.
    • Place the camera upside down with the lens facing you so that the battery compartment is facing up.
    • Place your thumb on the lid of the battery compartment making sure you put some pressure.
  2. Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: stap 2, afbeelding 1 van 3 Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: stap 2, afbeelding 2 van 3 Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: stap 2, afbeelding 3 van 3
    • Grab the camera with one hand, with your thumb still on the lid, apply pressure and slide to the right.
    • Lift the lid, exposing the battery and SD slot.
  3. Cyber-Shot DSC-H55 Battery Replacement, Removing Battery: stap 3, afbeelding 1 van 1
    • There is a small blue tab on the right of the compartment. In order to remove the battery, move this tab aside and the battery will pop up.
  4. Cyber-Shot DSC-H55 Battery Replacement, Inserting a New Battery: stap 4, afbeelding 1 van 2 Cyber-Shot DSC-H55 Battery Replacement, Inserting a New Battery: stap 4, afbeelding 2 van 2
    • Grab the new battery. Place the battery so that the arrow is pointing down and facing you. Next, slide the the battery into the battery compartment.
    • The blue tab will lock the battery into place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jazmin Young
608 Reputatie
5 handleidingen geschreven
USF Tampa, Team 6-2, Brown Winter 2015 Lid van USF Tampa, Team 6-2, Brown Winter 2015
USFT-BROWN-W15S6G2
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 20
Altijd: 991
