Ga door naar hoofdinhoud
Cuisinart Mini-Prep DLC-2A blender Shell Replacement
Wat je nodig hebt
  1. Cuisinart Mini-Prep DLC-2A blender Shell Replacement, Blender Jar: stap 1, afbeelding 1 van 2 Cuisinart Mini-Prep DLC-2A blender Shell Replacement, Blender Jar: stap 1, afbeelding 2 van 2
    • Identify the Jar of the Mini-Prep
  2. Cuisinart Mini-Prep DLC-2A blender Shell Replacement: stap 2, afbeelding 1 van 2 Cuisinart Mini-Prep DLC-2A blender Shell Replacement: stap 2, afbeelding 2 van 2
    • Place the Jar on top of the base by taking the bottom of jar and placing it through the blade accelerator.
  3. Cuisinart Mini-Prep DLC-2A blender Shell Replacement: stap 3, afbeelding 1 van 3 Cuisinart Mini-Prep DLC-2A blender Shell Replacement: stap 3, afbeelding 2 van 3 Cuisinart Mini-Prep DLC-2A blender Shell Replacement: stap 3, afbeelding 3 van 3
    • Notice that the written instructions on the top of the base remind the user to turn counter clock wise to lock the Jar into place.
    • Move the jar clock wise until it locks into place. Then to secure it turn it counter clock wise so that the handle sticks out the front of the blender.
  4. Cuisinart Mini-Prep DLC-2A blender Shell Replacement: stap 4, afbeelding 1 van 1
    • Place the blade inside using the jar, and on top of the motor propeller. [this is what spins the blade]
  5. Cuisinart Mini-Prep DLC-2A blender Shell Replacement: stap 5, afbeelding 1 van 3 Cuisinart Mini-Prep DLC-2A blender Shell Replacement: stap 5, afbeelding 2 van 3 Cuisinart Mini-Prep DLC-2A blender Shell Replacement: stap 5, afbeelding 3 van 3
    • first place the lid on top with the plastic attachment on the back right side.
    • Once the lid is on, rotate the lid counter clockwise so that it locks into the black locking mechanism in the back.
    • This secures the lid on top of the jar.
  6. Cuisinart Mini-Prep DLC-2A blender Shell Replacement: stap 6, afbeelding 1 van 1
    • Ta-da! You have officially learned how to replace the jar section of the blender.
Conclusie
dhydrt345473
103 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 186
