Inleiding
Cooking surfaces may be heating unevenly because the the plates and heating coils are out of alignment. This guide will take you through the steps to disassemble the device, allowing you to reassemble it correctly.
Wat je nodig hebt
Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
The aligned parts will allow the cooking surfaces to work properly.
Één andere persoon heeft deze handleiding voltooid.
