Ga door naar hoofdinhoud
Cuisinart Griddler GR-4N Cooking Surfaces Replacement
Wat je nodig hebt
  1. Cuisinart Griddler GR-4N Cooking Surfaces Replacement, Cooking Surfaces: stap 1, afbeelding 1 van 2 Cuisinart Griddler GR-4N Cooking Surfaces Replacement, Cooking Surfaces: stap 1, afbeelding 2 van 2
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: stap 2, afbeelding 1 van 1
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: stap 4, afbeelding 1 van 1
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: stap 5, afbeelding 1 van 2 Cuisinart Griddler GR-4N Cooking Surfaces Replacement: stap 5, afbeelding 2 van 2
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kayla Londono
632 Reputatie
4 handleidingen geschreven
Cal Poly, Team 1-12, Maness Spring 2016 Lid van Cal Poly, Team 1-12, Maness Spring 2016
CPSU-MANESS-S16S1G12
4 Leden
6 handleidingen geschreven
Één opmerking
The 'cooking plates' on my unit always fall off. I tried bending the tabs to make it tighter - did not help. Any ideas?
M S - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 25
Altijd: 4,099
