Ga door naar hoofdinhoud
Cuisinart DCC-3200 Hot Plate Replacement
Wat je nodig hebt
  1. Cuisinart DCC-3200 Hot Plate Replacement, Hot Plate: stap 1, afbeelding 1 van 1
    • Unplug the device and flip it over so the bottom is facing upwards.
    • Remove the four screws.
    • Remove the bottom panel.
  2. Cuisinart DCC-3200 Hot Plate Replacement: stap 2, afbeelding 1 van 1
    • Remove the two screws from the silver brace.
  3. Cuisinart DCC-3200 Hot Plate Replacement: stap 3, afbeelding 1 van 2 Cuisinart DCC-3200 Hot Plate Replacement: stap 3, afbeelding 2 van 2
    • Use a spudger to wedge the red tube off of the metal.
    • Repeat this for the other side of the silver pipe deeper in the device.
  4. Cuisinart DCC-3200 Hot Plate Replacement: stap 4, afbeelding 1 van 1
    • Pick up the middle pipe and slide the hot plate out of its area.
    • Apply new thermal paste to the hot plate.
Conclusie
Hamad Khan
385 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 8-3, Botvin Spring 2016 Lid van UMass Dartmouth, Team 8-3, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G3
3 Leden
5 opmerkingen
Where can one purchase the burner plate?
john Vet - Antwoord
Same question as John Vet
Bob Stimson - Antwoord
Did anyone ever get a response as to where a replacement could be purchased?
Joe Lubrant -
Did response provide required info?
Joe Lubrant - Antwoord
Same question: where can we purchase the burner plate?
Cresny - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 78
Altijd: 5,042
