Ga door naar hoofdinhoud
Cuisinart DCC-1200 Coffee Carafe Handle Replacement
Wat je nodig hebt
  1. Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: stap 1, afbeelding 1 van 3 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: stap 1, afbeelding 2 van 3 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: stap 1, afbeelding 3 van 3
    • Wedge the metal spudger between the plug and the handle.
    • Carefully pry the plug with the metal spudger by applying pressure around the plug.
    • Too much pressure and prying can damage the plug.
  2. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: stap 2, afbeelding 1 van 2 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: stap 2, afbeelding 2 van 2
    • Use the bit driver with the Phillips PH1 bit to remove the 27 millimeter long screw in the base of the handle.
  3. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: stap 3, afbeelding 1 van 1
    • Lift up on and remove the lid from the carafe.
  4. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: stap 4, afbeelding 1 van 2 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: stap 4, afbeelding 2 van 2
    • Position the metal spudger underneath the top cap of the handle.
    • Gently pry up to extract the upper assembly cap.
    • Pry carefully to prevent from causing aesthetic damage to upper assembly cap.
  5. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: stap 5, afbeelding 1 van 1
    • Use the bit driver with the Phillips PH1 to remove the 5 millimeter screw in upper assembly of handle.
    • Remove handle by lifting straight up.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Austin Wheaton
861 Reputatie
4 handleidingen geschreven
UW Stout, Team S8-G1, Ogden Spring 2018 Lid van UW Stout, Team S8-G1, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G1
4 Leden
5 handleidingen geschreven
Één opmerking
I needed this guide after my spouse put the carafe in the dishwasher and the handle sloshed no matter how much I shook it. It turns out water is easily trapped under the top cap; even though there's a drain hole into the handle, it doesn't seem to want to drain. I've wiped it off and left it to dry completely before reassembling it.
Max - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 36
Altijd: 3,668
