Inleiding
Does your Cuisinart coffee maker leak water from the bottom of the machine? This guide will show how to fix the problem by checking and replacing the internal hoses. You will need a tweezers and the bit driver with the T10 driver bit.
Wat je nodig hebt
Flip the coffee maker over so the bottom is facing upwards.
Use the screwdriver with size 4 extension with the T10 Torx bit to remove all four 17 mm long screws.
Lift the bottom cover off the bottom of the coffee maker.
3 andere personen hebben deze handleiding voltooid.
10 opmerkingen
I think this was a brand new coffee maker used for this demo. My hoses will not budge. I would guess they soften up and permanently adhere to heating element over time. Also, from other videos, there is a ball in the hose (to control direction of water.) Not sure if you can replace with any old hose.
Oh yeah that really helped, why not tell us where you got the hose or what type it is?
Silicon Durometer 50 or 70 or is it something else, totally useless site, waste of time.
Wish someone would answer this good question…
Where to get, and what kind of replacement hoses ??? Do you need a new ball in little filter , or do you need the filter at all ???
https://www.amazon.com/gp/product/B003SY... this is where I ordered red hose from. $5.69 for a foot.
