Ga door naar hoofdinhoud
Cuisinart DCC-1100 Drip Spring Replacement
Wat je nodig hebt
  1. Cuisinart DCC-1100 Drip Spring Replacement, Drip Spring: stap 1, afbeelding 1 van 1
    • Unplug the coffee maker.
  2. Cuisinart DCC-1100 Drip Spring Replacement: stap 2, afbeelding 1 van 1
    • Remove the coffee pot and open the top lid.
  3. Cuisinart DCC-1100 Drip Spring Replacement: stap 3, afbeelding 1 van 2 Cuisinart DCC-1100 Drip Spring Replacement: stap 3, afbeelding 2 van 2
    • Remove the basket filter holder.
  4. Cuisinart DCC-1100 Drip Spring Replacement: stap 4, afbeelding 1 van 1
    • Remove the basket filter from the holder.
  5. Cuisinart DCC-1100 Drip Spring Replacement: stap 5, afbeelding 1 van 1
    • Press up on the drip spring mechanism.
  6. Cuisinart DCC-1100 Drip Spring Replacement: stap 6, afbeelding 1 van 2 Cuisinart DCC-1100 Drip Spring Replacement: stap 6, afbeelding 2 van 2
    • While pressing up on the drip spring mechanism, remove the clear round plastic retainer holding the mechanism in place.
  7. Cuisinart DCC-1100 Drip Spring Replacement: stap 7, afbeelding 1 van 1
    • Remove the spring from the dripper.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Josh Harvey
889 Reputatie
4 handleidingen geschreven
USF Tampa, Team S20-G4, Passmore Spring 2018 Lid van USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
4 Leden
7 handleidingen geschreven
4 opmerkingen
Where do you find replacement springs?
Mrich - Antwoord
I have Cuisinart's Grind & Brew machine and it has an identical drip plug assembly. I measured carefully with a caliper and arrived at this spring size: 12 mm OD, 0.5 mm wire diameter, 30 mm free length. https://www.amazon.com/uxcell-0-5mmx12mm...
Chris Rockett -
My basket holder has thrown off the clear plastic retainer ring; is there a replacement part I can purchase?
Raymond Classen - Antwoord
When the basket holder came apart - the clear plasted retainer ring came off of mine, also. Can you just purchase this piece?
ncrenshaw4 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 54
Altijd: 11,619
