Ga door naar hoofdinhoud
Cuisinart CPB-380 Power Cord Replacement
Wat je nodig hebt
  1. Cuisinart CPB-380 Power Cord Replacement, Cuisinart CPB-380 Disassembly: stap 1, afbeelding 1 van 3 Cuisinart CPB-380 Power Cord Replacement, Cuisinart CPB-380 Disassembly: stap 1, afbeelding 2 van 3 Cuisinart CPB-380 Power Cord Replacement, Cuisinart CPB-380 Disassembly: stap 1, afbeelding 3 van 3
    • Turn the device upside down.
    • Remove all four rubber feet by prying them out using the metal spudger.
    • Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
  2. Cuisinart CPB-380 Power Cord Replacement: stap 2, afbeelding 1 van 2 Cuisinart CPB-380 Power Cord Replacement: stap 2, afbeelding 2 van 2
    • Remove the base from the body of the blender.
  3. Cuisinart CPB-380 Power Cord Replacement: stap 3, afbeelding 1 van 3 Cuisinart CPB-380 Power Cord Replacement: stap 3, afbeelding 2 van 3 Cuisinart CPB-380 Power Cord Replacement: stap 3, afbeelding 3 van 3
    • Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
    • Gently move the wire aside so that it is not in the way.
  4. Cuisinart CPB-380 Power Cord Replacement: stap 4, afbeelding 1 van 3 Cuisinart CPB-380 Power Cord Replacement: stap 4, afbeelding 2 van 3 Cuisinart CPB-380 Power Cord Replacement: stap 4, afbeelding 3 van 3
    • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
    • Gently remove the black cover.
    • Underneath, you will see a clear plastic cover that should be removed as well.
  5. Cuisinart CPB-380 Power Cord Replacement: stap 5, afbeelding 1 van 2 Cuisinart CPB-380 Power Cord Replacement: stap 5, afbeelding 2 van 2
    • Cut the zip tie that holds the black, blue, red, and yellow wires together.
    • Take care not to cut the wires.
  6. Cuisinart CPB-380 Power Cord Replacement, Power Cord: stap 6, afbeelding 1 van 2 Cuisinart CPB-380 Power Cord Replacement, Power Cord: stap 6, afbeelding 2 van 2
    • Remove the 2 black, yellow, and red wires from circuit board by push down on the tab to release and then pull up.
  7. Cuisinart CPB-380 Power Cord Replacement: stap 7, afbeelding 1 van 1
    • Pinch perpendicular to the flat surface and pull out the black wire.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 138
