Ga door naar hoofdinhoud
Cuisinart CPB-380 Motor Replacement
Wat je nodig hebt
  1. Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: stap 1, afbeelding 1 van 3 Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: stap 1, afbeelding 2 van 3 Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: stap 1, afbeelding 3 van 3
    • Turn the device upside down.
    • Remove all four rubber feet by prying them out using the metal spudger.
    • Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
  2. Cuisinart CPB-380 Motor Replacement: stap 2, afbeelding 1 van 2 Cuisinart CPB-380 Motor Replacement: stap 2, afbeelding 2 van 2
    • Remove the base from the body of the blender.
  3. Cuisinart CPB-380 Motor Replacement: stap 3, afbeelding 1 van 3 Cuisinart CPB-380 Motor Replacement: stap 3, afbeelding 2 van 3 Cuisinart CPB-380 Motor Replacement: stap 3, afbeelding 3 van 3
    • Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
    • Gently move the wire aside so that it is not in the way.
  4. Cuisinart CPB-380 Motor Replacement: stap 4, afbeelding 1 van 3 Cuisinart CPB-380 Motor Replacement: stap 4, afbeelding 2 van 3 Cuisinart CPB-380 Motor Replacement: stap 4, afbeelding 3 van 3
    • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
    • Gently remove the black cover.
    • Underneath, you will see a clear plastic cover that should be removed as well.
  5. Cuisinart CPB-380 Motor Replacement: stap 5, afbeelding 1 van 2 Cuisinart CPB-380 Motor Replacement: stap 5, afbeelding 2 van 2
    • Cut the zip tie that holds the black, blue, red, and yellow wires together.
    • Take care not to cut the wires.
  6. Cuisinart CPB-380 Motor Replacement, Motor: stap 6, afbeelding 1 van 2 Cuisinart CPB-380 Motor Replacement, Motor: stap 6, afbeelding 2 van 2
    • Remove the four 13mm screws holding down the frame located at the bottom of the inverted blender using the Phillips #2 screwdriver.
    • Remove frame.
  7. Cuisinart CPB-380 Motor Replacement: stap 7, afbeelding 1 van 2 Cuisinart CPB-380 Motor Replacement: stap 7, afbeelding 2 van 2
    • Grab the motor by the black gear and the white filter.
    • Unscrew the black gear.
  8. Cuisinart CPB-380 Motor Replacement: stap 8, afbeelding 1 van 3 Cuisinart CPB-380 Motor Replacement: stap 8, afbeelding 2 van 3 Cuisinart CPB-380 Motor Replacement: stap 8, afbeelding 3 van 3
    • With the metal spudger remove the four rubber stoppers.
    • Remove the four 13mm screws with the Phillips #2 screwdriver.
  9. Cuisinart CPB-380 Motor Replacement: stap 9, afbeelding 1 van 1
    • Separate the top from the motor.
    • Pinch perpendicular to the flat surface and pull out the blue wire.
Conclusie
2 opmerkingen
What is the part number and price for Cuisinart CPB-380 Motor?
Paul Hagen - Antwoord
What is the part number and price for Cuisinart CBD-380 motor and price....
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 51
Altijd: 3,182
