Ga door naar hoofdinhoud
Cruiser Bike Rear Wheel Replacement
Wat je nodig hebt
  1. Cruiser Bike Rear Wheel Replacement, Rear Wheel: stap 1, afbeelding 1 van 1
    • Flip your bike so the seat and handlebars are on the ground.
    • This will make it easier to access tire.
  2. Cruiser Bike Rear Wheel Replacement: stap 2, afbeelding 1 van 1
    • Slip the chain onto the crank and rear cog. Then insert wheel into rear drop-outs.
    • Make sure that the chain is on the correct side of the wheel.
    • Handle the chain carefully to ensure a successful tire replacement.
  3. Cruiser Bike Rear Wheel Replacement: stap 3, afbeelding 1 van 1
    • Tighten brake strap using screwdriver and 10 mm socket wrench.
    • Hold the nut on the inside (near the spokes) with wrench as you tighten the screw with the screwdriver.
    • You will know the socket wrench is has finished tightening when you feel resistance.
  4. Cruiser Bike Rear Wheel Replacement: stap 4, afbeelding 1 van 1
    • Center the wheel and pull back to tighten the chain.
    • If the bike wheel is unusable use tire levers to remove tire.
  5. Cruiser Bike Rear Wheel Replacement: stap 5, afbeelding 1 van 1
    • With the wheel pulled back, tighten the two axle nuts using the 15 mm socket wrench.
    • Tighten the non-drive side (side without the chain) first.
    • The wheel will angle as you tighten. Keep it centered with your hand as you finish tightening both axle nuts.
    • Use a tire pump to make sure the tire is full of air and ready to ride.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Erin Heimburge
30 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 55
Altijd: 11,066
