Ga door naar hoofdinhoud
Crosley CR704 Speaker Replacement
Wat je nodig hebt
  1. Crosley CR704 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Using your Philips head screwdriver, remove the 10 outer black screws from the back of the device.
  2. Crosley CR704 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Gently remove the back panel of the device being careful not to unplug any internal wires.
  3. Crosley CR704 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Using your Phillips head screwdriver, remove the 4 brass speaker screws.
    • Be careful to not remove the speaker housing screws, which surround the speaker screws.
  4. Crosley CR704 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Carefully pull the wires out of their connections from the back of the speaker.
    • Don't forget which wire goes with which connection!
Conclusie
To reassemble, follow these instructions in reverse order. Then test by playing a tune. We suggest "Live at the Apollo" by James Brown.
Één andere persoon heeft deze handleiding voltooid.
MarkAnthony
772 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 Lid van UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G4
3 Leden
Één opmerking
I've got this but the music plays super quietly on the records I'm not able to turn up the sound would this be the solution?
ninjadaniel66 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 2,882
