Ga door naar hoofdinhoud
Crosley CR704 Drive Belt Replacement
Wat je nodig hebt
  1. Crosley CR704 Drive Belt Replacement, Safety: stap 1, afbeelding 1 van 1
    • Unplug power cable (if it's plugged in) so you don't electrocute yourself (or loved ones).
    • Secure tone arm so it doesn't hurt itself (or you).
  2. Crosley CR704 Drive Belt Replacement: stap 2, afbeelding 1 van 1
    • Using a flat edge (such as a spudger or a flathead screwdriver) pry the C-clamp from the center spindle by wedging the flat edge between the spindle and the C-clamp.
    • The C-clamp may pop off unexpectedly, so be careful it doesn't fall somewhere hard to reach.
    • The C-clamp his what holds the platter in place. With it removed, you can now et under the platter.
  3. Crosley CR704 Drive Belt Replacement: stap 3, afbeelding 1 van 2 Crosley CR704 Drive Belt Replacement: stap 3, afbeelding 2 van 2
    • You can now lift the platter.
    • The drive-belt will be found either around the bottom of the platter or around the motor.
    • If the drive-belt is broken it will need to be replaced. If it is loose, you can simply re-secure it.
    • To replace the belt, wrap it around the inner circle of the bottom of the platter. Then stretch the belt around one of the two pegs found near the outer edge of the bottom of the platter.
    • This will be a snug fit, so be careful not to snap the rubber belt!
  4. Crosley CR704 Drive Belt Replacement: stap 5, afbeelding 1 van 1
    • Using your thumb as a guide, place the platter back onto the motor so that the peg holding the drive-belt wraps around the outside of the brass motor post.
  5. Crosley CR704 Drive Belt Replacement: stap 6, afbeelding 1 van 1
    • Secure the platter all the way down and spin the platter clockwise until you hear a pop and feel resistance from the drive-belt catching.
  6. Crosley CR704 Drive Belt Replacement: stap 7, afbeelding 1 van 1
    • You can replace the C-clamp by shoving it back into place around the center spindle (this will require some force).
    • It's not necessary to replace the C-clamp unless you plan on moving the device around.
Conclusie
Test by playing a record. We suggest "Take Five" by The Dave Brubeck Quartet.
7 andere personen hebben deze handleiding voltooid.
MarkAnthony
772 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 Lid van UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G4
3 Leden
4 opmerkingen
followed instructions multiple times—hear and see that the drive motor is spinning but platter is not— what’s wrong
Holly Shulman - Antwoord
The belt is fine and placed correctly but the record speed (33 and 1/3) is off. Spins too fast.
Suggestions?
Gary Sivertsen - Antwoord
What is the size of the c-clip / c-clamp? I’d like to replace one.
Meaghan Walsh Gerard - Antwoord
Perfect! Needed to add some sewing oil to reduce squeaking, and didn't have a clue how it went back on. This helped immensely!
Karl Althaus - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 86
Altijd: 24,377
