Ga door naar hoofdinhoud
Crosley CR704 Control Knobs Replacement
Wat je nodig hebt
  1. Crosley CR704 Control Knobs Replacement, Safety: stap 1, afbeelding 1 van 1
    • Unplug the power cable if it is plugged in so that you don't electrocute yourself or loved ones.
    • Make sure the turntable cover is closed so that nothing jostles out of place.
  2. Crosley CR704 Control Knobs Replacement: stap 2, afbeelding 1 van 1
    • Using a spudger, gain a position of leverage and insert the end of the spudger into the gap between the radio knob and the device.
    • With some force, pry the knob off of its peg.
    • The knob should slide off smoothly, but beware of flying knobs!
  3. Crosley CR704 Control Knobs Replacement: stap 3, afbeelding 1 van 1
    • Applying some force, insert the replacement knob onto the peg.
Conclusie
Test by turning on your radio and playing a tune. We suggest "Last Dance" by Dona Summer.
MarkAnthony
772 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 Lid van UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 1,818
