Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide is going to show you an easy way to replace the turning band in you Crosley CR42. So you can enjoy your LP sooner rather than later.
Gereedschap
Geen gereedschap opgegeven.
Onderdelen
  1. Check troubleshooting wiki to make sure you aren't doing way more work than you have to!
    • Check troubleshooting wiki to make sure you aren't doing way more work than you have to!
    • If you believe the band may be broken or out of place, start by unplugging the record player.
  2. Make sure the needle is in its resting position off to the side. Gently remove the turntable from the device by lifting it directly upward.
    • Make sure the needle is in its resting position off to the side.
    • Gently remove the turntable from the device by lifting it directly upward.
  3. Find the band, it may have fallen into the inside of the record player as you removed the turntable.
    • Find the band, it may have fallen into the inside of the record player as you removed the turntable.
    • Inspect your band for any tears, rips, or obvious signs of stretching.
  4. Flip the turntable over.
    • Flip the turntable over.
    • Locate the notch on the back side of the turntable.
    • The notch will be on the outside edge of the turntable.
  5. Wrap the band around the inner circle of the turntable and gently pull the band until you get to the notch. Loop the band around the notch, the band should be taut.
    • Wrap the band around the inner circle of the turntable and gently pull the band until you get to the notch.
    • Loop the band around the notch, the band should be taut.
  6. Place the turntable back onto the device. Make sure to line up the band with the turning knob, to ensure the band is properly placed.
    • Place the turntable back onto the device.
    • Make sure to line up the band with the turning knob, to ensure the band is properly placed.
  7. After the turntable is back on the device, gently turn it clockwise until you hear a 'click.'
    • After the turntable is back on the device, gently turn it clockwise until you hear a 'click.'
    • Job well done!
Eindstreep
Roberto Rosila
316 Reputatie
3 handleidingen geschreven
Cal Poly, Team 1-38, Maness Winter 2014 Lid van Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
4 Leden
5 handleidingen geschreven
Één commentaar
My CR42 has a plastic piece that will not let me simply pull the turntable off. I don't want to try to hard to break it, but I also don't know how to get it off to replace the band.
athena - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 48
Altijd: 3,070
