Ga door naar hoofdinhoud
Cricut Maker Top Door/ Lid Replacement
Wat je nodig hebt
  1. Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: stap 1, afbeelding 1 van 3 Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: stap 1, afbeelding 2 van 3 Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: stap 1, afbeelding 3 van 3
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
  2. Cricut Maker Top Door/ Lid Replacement: stap 2, afbeelding 1 van 2 Cricut Maker Top Door/ Lid Replacement: stap 2, afbeelding 2 van 2
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
  3. Cricut Maker Top Door/ Lid Replacement: stap 3, afbeelding 1 van 3 Cricut Maker Top Door/ Lid Replacement: stap 3, afbeelding 2 van 3 Cricut Maker Top Door/ Lid Replacement: stap 3, afbeelding 3 van 3
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
  4. Cricut Maker Top Door/ Lid Replacement: stap 4, afbeelding 1 van 1
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Devyn White
1.131 Reputatie
5 handleidingen geschreven
2Gids Commentaar
Where i can buy Cricut Maker Top Door/ Lid Replacement?
Maria Ventura - Antwoord
Our Circut Maker lid will not stay open. It closes on its own within a few seconds. I was wondering if there was a fix or a repair I could do. It is 10 months old and Circut told us it wasn’t covered under the two year warranty.
K. Moore
Keith Moore - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 127
Altijd: 3,686
