Inleiding
When challenged by malfunctions of Cricut Maker machines, things can result in difficulty and stress. A common malfunction is the instability of loading in Cricut mats due to worn-out rubber rollers. Only further assistance can be done by a Cricut Maker owner after a year of warranty if actions are taken within one's hands.
Instead of tossing a Cricut Maker machine due to malfunctions, with this guide, replacing rubber rollers from a Cricut Maker machine can be the resolution for more opportunities in creating projects.
Wat je nodig hebt
Replacing the rubber rollers begins with the movement of removing the top white rectangle plaque that sits at the top of the Cricut.
Use a 1.5mm flat-head bit for removal of the plastic white plaque.
After removing the four black screws, locate the seven silver screws that then sit below the top portion of the machine. They can be challenging to identify as they are hidden, so move the machine to an angle where each screw is visible to remove.
Remove all seven silver screws using a 1 mm flat-head bit.
4 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
Tutoriel au top, ma maker peut encore avoir de longues heures devant elle. Merci!
Replacement rollers are available as a kit from Amazon for Cricut Maker 3:
