Ga door naar hoofdinhoud
Creative Ziio 7" Motherboard Replacement
Wat je nodig hebt
  1. Creative Ziio 7" Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 3 Creative Ziio 7" Motherboard Replacement, Back Panel: stap 1, afbeelding 2 van 3 Creative Ziio 7" Motherboard Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" Motherboard Replacement, Motherboard: stap 2, afbeelding 1 van 3 Creative Ziio 7" Motherboard Replacement, Motherboard: stap 2, afbeelding 2 van 3 Creative Ziio 7" Motherboard Replacement, Motherboard: stap 2, afbeelding 3 van 3
    • Remove the copper plate covering the motherboard by desoldering the ten solder points.
    • The solder point in the bottom right corner is marked but hidden by the soldering iron.
  3. Creative Ziio 7" Motherboard Replacement: stap 3, afbeelding 1 van 2 Creative Ziio 7" Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the adhesive tape covering the three wires connected to the motherboard.
    • Desolder the solder points connecting the wires to the motherboard.
  4. Creative Ziio 7" Motherboard Replacement: stap 4, afbeelding 1 van 3 Creative Ziio 7" Motherboard Replacement: stap 4, afbeelding 2 van 3 Creative Ziio 7" Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Disconnect the ribbon cable that is attached underneath the copper plate.
    • Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board.
  5. Creative Ziio 7" Motherboard Replacement: stap 5, afbeelding 1 van 2 Creative Ziio 7" Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 4mm Philips #00 screws holding the motherboard to the casing.
    • The copper plate will be removed by now. However, the picture does not show this.
  6. Creative Ziio 7" Motherboard Replacement: stap 6, afbeelding 1 van 2 Creative Ziio 7" Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Lift up the motherboard.
    • A mesh-looking strip on the left side will be connected to the bottom of the motherboard.
    • Remove the tape on top of the strip and use tweezers or pliers to pull on the strip to unplug it.
  7. Creative Ziio 7" Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the red and black wires with a soldering iron that are located underneath the motherboard.
    • Do not cut or damage the wires in the process. They will be needed for the new motherboard.
  8. Creative Ziio 7" Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the old motherboard and dispose of it resposibly.
Conclusie
Benedict Samoy
25 Reputatie
2 handleidingen geschreven
Cal Poly, Team 14-10, Maness Spring 2013 Lid van Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 1,194
